Odd BOOTMGR issue
16 Jul 2008
I had some issues with my system drive on my main PC, and to cut a long story short I lost the system partition on my main drive. The actual partition that had vista on it (i.e. C:\Windows\) is still there, but the boot partition (that calls itself System) is gone... or more precisely is showing up as raw formatted. I opened it up with a partition tool and it is just jargon. The entire partition looks as if it's been fried.
The original message that was shown was "Operating system not found."
I tried the Vista CD's startup repair tool and the whole "bootrec /fixboot" routine to no avail. The system repair doesn't recognise that I even have Windows installed and bootrec just fails.
I looked in my C drive (mounted using a USB controller) and found that C:\Boot was missing. I recreated the drive and copied the directory across from another Vista machine. I also formatted the system partition (the one that broke) as NTFS, then copied the contents of another machine's system partition to it.
Now I get the error:
BOOTMGR is missing. Press Ctrl+Alt+Del to restart.
I assume that it's now found the operating system but it just can't boot it, so I've tried the repair stuff again, but they just don't work. Any ideas?
Cheers,
Burningmace
