Odd DHCP issue
28 Oct 2002
Hiraeth
Ok, so set up a scope for the wireless clients in work. 10.100.120.10 - 10.100.123.254 subnet 255.255.252.0.
All has been working fine until recently where everything with a 10.100.120.x address is fine, but once it goes over into the next range (10.100.121.x) the devices are assigned the correct gateway etc, but cannot get internet/internal access and can't even ping the default gateway
What gives? Is it the DHCP server or the wireless controller (Dell Aruba)
That is not the 'next range' on a 10.100.121.0/22 subnet, it is the same network (range). The issue is as above, the clients have the wrong netmask assigned or the router has, that's what it seems based on what you've put.
