Hi all long time no speaky
Any way thought I would post on here my experiance with my PC hard locking in windows and worst of all the BIOS.
Specs
Asus maximus formula XI
I7 7700K
16GB ram
and the cause I think and hope
GeForce GTX 1080 DirectCU III Strix Advanced Gaming Aura RGB 8192MB
Now yesterday one was just playing a game and my PC hard locked still had fans and display but it was locked could not use mouse nor keyboard so hard to hard reset.
So though ha just windows being a sod so restarted it and instantly locked up blue screens etc etc.
So thought OK shall go into BIOS and see whats up.
I was in the BIOS for about 5 seconds and bam same thing fans going display was fine just locked could not use mouse nor keyboard.
So as you know its now a case of finding out the issue so I removed GPU and started PC up again all seemed fine BIOS,Windows etc.
So put GPU back in and still seems fine.
I am happy but yet at the same time worried as I dont know for sure what the issue was or could have been or still is?.
My question to you lot is does a loose GPU in a PCI-E slot cause these kinds of issues if so I would have expected the displays to have suffered to but they never.
Or could it have been a loose power suplly cable? even though the little white LEDs showed all was fine that is near the power connectors on the GPU.
I am going to keep an eye on it as I am still not convinced lucky for me my whole PC is still under warrenty but that would suck
I built the pc my self parts supplied from OCUK its been fine for nearly a whole year July the 1st infact.
P.S forgot to say temps are perfect under load and idle voltages not sure .
https://i.imgur.com/YML6us2.png
https://i.imgur.com/py36F9h.png
Thanks in advance.
.Any way thought I would post on here my experiance with my PC hard locking in windows and worst of all the BIOS.
Specs
I7 7700K
16GB ram
I built the pc my self parts supplied from OCUK its been fine for nearly a whole year July the 1st infact.P.S forgot to say temps are perfect under load and idle voltages not sure .
Thanks in advance.
