I have a rather odd Memory issue which is throwing various different BSODS under heavy use.
The PC is ASUS X99 Deluxe with a 5820 and 4X Corsair LPX 2666 8GB sticks like this:
https://www.overclockers.co.uk/cors...el-kit-black-cmk32gx4m4a2666c1-my-419-cs.html
If the system is run with just one stick then everything is fine, and each individual stick has been tested and found stable.
If I put two stick in (16GB), in any combination, again the system is stable.
If I put all four sticks (32GB) in though I get the BSOD
Just for the sake of answering the obvious They are in the correct slots, the XMP switch on the board is switched to on, and profile 2 is selected. Running at a slower speed makes no difference, it is a clean install of Windows 10, but it did this on the previous installation too.
Any ideas gratefully received !
