Odd noise when running diagnostics on my raptor
uZi
uZi
1 Aug 2003
Hi, my 150gig raptor (around 2 1/2 months old) has been making some repetitive noises, like a clicking every 10 seconds or so. So I ran the WD diagnostic tools, both the tests pass. However, when running the quick test (smart check afaik), the drives makes a very odd whirring noises as it spins up for the test, after about 20-30 seconds the noise stops and the test continues and passes.
I am not sure if the noises are normal as I've not had a raptor before. Is this normal or is there something wrong with my drive?
Cheers
