Odd overclocking problem
18 Oct 2002
North Yorkshire
Having a weird issue with my setup as follows
e6300
p5n-e sli
2gig crucial 5300
7800gt
corsair 520 psu
+ 2 hd and 2 dvd burners
(this setup is orthos stable on small and blend for 12 hours each and 3dmark stable for 8 hours or so) also downclocked from 3.4 to 3 , more volts for cpu ram board etc.
Problem as follows -
If I play an avi or dvd eventually the system will lock up (seems to lockup quicker with ffdshow)
Things ive tried changing -
Graphics card, CPU, ram
a friend of mine has the same board , so tried his hd with his windows install on mine (ide) , mine is sata , ruling out a sata problem , still locks up.
This video locking issue only happens when overclocked, suggesting it’s a motherboard issue even though its orthos stable small and blend.
Before i order another motherboard does anyone have any suggestions?
Cheers
I had the same problem running ffdshow with my P5N-E along with an overclocked CPU.
At stock it would run fine but once I cranked the FSB up it kicked off. Especially when it came to converting AVI's.
I uninstalled it and installed the All in 1 Codec Pack from here and it worked.
Thanks for the reply
i origionaly thought it was a compatability problem with ther board and ffdshow , but my friends pc with the same motherboard and overclocked has non of this.
If I just use the xvid decoder it will be fine for days but it will still randomly freeze.
Hi
I’m using ac3filter 1.45 ( have actually tested with no sound card in and onboard audio off with ac3 filter not installed)
I don’t have vobsub installed
After you confirmed you had ffdshow issues with yours I am now testing the divx6.6 codec , letting it decode all mp4 , see what happens with this.
Having thought about it, the only real difference to my mates rig is that he is using an ati card :confused:
many thanks for the reply
