Odd problem
12 Oct 2005
Morning,
Just built a new build:
Gigabyte Z97X-UD3H-BK
i7 4790K
EVGA SuperNova G2 850W '80 Plus Gold' Modular Power Supply
TeamGroup Vulcan RED 8GB (2x4GB) DDR3 PC3-19200C11 2400MHz Dual Channel Kit
670 GTX.
When I start the PC, the PC boots up, however the display stays off / comes on for a brief second then goes into standby and doesn't wake up. If I restart the PC it then wakes up.
Also with my sound, if the PC goes into hibernation the sound card/sound turns off.
GPU is in the 2nd slot as sound card is in 1st/2nd PCI slot.
I've disabled onboard gfx, told it to use 2nd PCIE as main slot, installed old drivers for GFX but still no fix.
With regards to sound, there have been a few fixes but not exactly ideal, ie disable sound device then enable to get sound back but this shouldn't be required/isn't a proper fix...
Is your motherboard bios up to date?
Sounds like an Nvidia driver issue tbh.
Not sure about the audio though but my guess would be drivers again.
Rich
