Odd resolution / temp problem
5 Nov 2007
North East
Hey all
After turning my pc (see sig for spec) on just now, i noticed that the desktop resolution had changed itself to 800 x 600. It wasn't that last night, its always set at 1680 x 1050. Bit weird i thought, so changed it back to 1680 x 1050, no problems.
I then opened Rivatuner 2.24 to find that the temperature was very low, about 32°C. Idle its always in the 40's. Also checked Speedfan, its set at its normal cool and quiet setting of 65%, nothing different there. Booted up a quick game, no problems there either.
Using the latest drivers as well, 186.18
Right now its up to 35°C, still low for what it normally is, any idea to what might have caused the resolution to drop to the lowest setting and it being lower than normal temp?
