Odd Vista boot up problem
5 Mar 2009
Hi all,
I've just built myself a new pc using bits 'n bobs from OcUK, and while general performance is amazing, I've got a bit of an odd problem.
For reference, the main components in my new pc are:
Core i7 920
6gb ram
1gb 4870
Gigabyte EX58-UD3R
Vista 64bit
It's only a niggling problem, but basically, if i boot my pc up and I've left a disc in the dvd drive, Vista will hang on a blank screen for ages, constantly accessing the drive, but if I open the dvd drive, it'll continue starting up. I've never left it long enough to see if it will eventually boot up without opening the drive.
If I'm booting the pc up and the dvd drive it empty, Vista will start straight up very quickly.
Has anyone else experienced this problem, or any idea's what I might be able to do to sort it out (apart from stop being lazy and making sure the drive is empty before I shut the pc down!)? I don't remember having this problem on my old pc with XP Pro on it - it would boot fine with a dvd in the drive.
Just to note, the only boot device I've got enabled in the bios is the hdd.
Apart from this, its been incredible going from my previous system (Athlon 64 3800!!!) to the Core i7.
Cheers for any help.
Well, you've no idea how stupid I feel now, and how grateful I am!
Setting the dvd as the 2nd boot device seems to have done the trick.
enjoy the pc, i have enoughy money in the bank for that, but i can't justify the upgrade from my q6600 :(
Well, lo and behold, I booted the pc up today (had a dvd in the drive, tut) and its stalling again on boot up.
Its doing exactly the same as before. With no disc in, it gets past the little scrolling bar as Vista is loading, then the screen momentarly goes blank and my desktop loads. But as before with a disc in, it gets just to the blank screen before my desktop should appear, and just hangs accessing the dvd drive.
Checked the bios and it's still set with hdd as primary boot and the dvd drive as secondary as I'd switched it to last night. I must have rebooted at least two or three times last night to test and it booted up fine each time. :confused:
