** Of Course We Are First... **
im really confused what are you after?
the h80 and 100 are 120mm versions
the 90 and 110 are 140mm versions
take your pick
As an aside do we think this is likely to force nzxts hands to lower their prices to match?
How is that confusing> You answered the question. My case only mounts 120mm fans. these offerings are 140mm. So they wont fit in my case. Ahh forget it.
So you're asking if there will be a 120mm version of the H90. Well, the H80 covers that so they don't need to make a 120mm version of it.
That said, the H80 is CoolIT based whereas the H90 is an Asetek unit so what you would be asking is for Asetek to make a 120mm version, in which case that's what the H70 is.
