** Official OcUK Power Consumption Thread **
rjk
rjk
OcUK Staff
8 Aug 2007
Hi Guys
Following the very successful launch of the Energenie range at OcUK, we thought it would be a great idea to gauge how much power certain setups use.
OcUK sells a very accurate power meter that shows the consumption from the wall.
Energenie Power Meter @ £9.80 inc VAT
The Energy Saving Power Meter will measure the energy use (and calculate costs) of running household appliances. This helps you lower your power bill and reduce carbon emissions.
Ideal for keeping an eye on your system power consuption.
Only £12.99 inc VAT.
ORDER NOW
If you already have a power meter, then post away!
To enter your results, please use this template.
Code:
System Specification:
CPU: Name & Clockspeed
GPU: QTYx, Name, Corespeed
System Spec: Memory, Motherboard, Storage, Cooling Solution
Power Supply: Brand/Model/Wattage
Power Consumption:
Standby: 000w
Desktop Idle: 000w
Prime95 Blend: 000w
Prime95 Blend + Furmark: 000w
this should hopefully gather a lot of information on cow certain configurations use power.
here is an example from me to start with using the OcUK Ultima XXX System
CPU: Intel i7 990X & 4.2GHz
GPU: 2x, Nvidia GTX 590, 607Mhz
System Spec: Dominator GT 2000MHz, Gigabyte OC, RevoDrive + WD Black, Custom Water
Power Supply: OCZ ZX 1250w
Power Consumption:
Standby: 2w
Desktop Idle: 276w
Prime95 Blend: 346w
Prime95 Blend + Furmark: 860w
System specification:
CPU Intel i7 920 @ 4ghz
GPU: 1 X 580 GTX Ocuk STD
watercooling and 1 SSD, and 2 mechanical hard Drives, 6GB Patriot ram @ 1600MHZ
PSU: PC Power & Cooling 750w
Power Consumption:
Desktop Idle: 210w
Prime 95 load: 330w
Full load with Prime & Furmark: 500w
Just out of interest, how much difference does Intel Stepspeed make on power consumption when in idle?
Are the figures you guys have (at idle) with a fixed cpu clock i.e. fixed voltage, or is it allowed to drop?
Code:
CPU: AMD [email protected].
GPU: 1 x 560ti Twin Frozr II, 880mhz.
System Spec: 8GB RAM, 1 BlackGold TV Tuner, 2xF3 1TGB, HDD 500GB, Vertex2E 60GB.
Power Supply: Corsair HX620W.
Power Consumption:
Standby: 0.5w
Desktop Idle: 170w
Prime95 Blend: 300w
Prime95 Blend + Furmark: 430W
