ok so i was reinsalling the drivers for my his x1950pro agp on vista hp64 and i went off to make a cup of tea
when i got back to my pc my monitor just displayed "out of range" in a box
so i reset it and it loaded up but at the log on screen the screen goes blank and again the message "out of range" but i can still hear the start up sound
this happened before when i plugged in by hdtv and i know all it means is that the resolution is not supported by my monitor. last time i plugged in my old monitor and changed the res and fixed it. but neither monitor works this time and to plug in my hdtv i need to use s-video so i cant do that either
i can load up in safe mode, and i tried driver cleaner but i still get the same results, and i cant install any drivers in safe mode
im trying to find the system restore in vista but i cant![Roll Eyes :rolleyes: :rolleyes:](/styles/default/xenforo/vbSmilies/Normal/rolleyes.gif)
so....
any ideas?
any help at all appreciated
EDIT
ok i found the system restore, and no ******* restore points are found!! wtf???! i thought vista made one every time you installed something?
also when i try to install the drivers in safe mode i get the error "failed to load detection driver" if thats any help![Frown :( :(](/styles/default/xenforo/vbSmilies/Normal/frown.gif)
so....
any ideas?
![Smile :) :)](/styles/default/xenforo/vbSmilies/Normal/smile.gif)
EDIT
