Oh dear... need help specing a PSU
22 May 2009
Scotland
Hello folks!
I've helped a very fruggle buddy build a new PC. Now he told me his PSU would work find for the new rig, doesn't seem to have the eight point CPU cable needed though! Doh!
His current PSU is an Antec Neo 480w modular PSU.
Just boguht the "Radon Torosaur" Intel Core i5 2500K 3.30GHz @ 4.40GHz Overclocked Bundle - Gigabyte.... https://www.overclockers.co.uk/showproduct.php?prodid=BU-062-OE
Now the Mobo seems to need the newer 4+4 CPU connector and his PSU only has the standard 4pin.
Can someone please help us out and spec me a cheap PSU.
I did at least convince him to invest in a good sized case - Fractal Design Define XL Full Tower Case
Thanking you in advance gentlemen!
Do you think a 4pin would cover the CPU clocked as above? What is the overclock Voltage do you think?
Ah, forgot about that, seem to remember using the 4pin into 8pin socket is fine for standard pc's, the 8pin is needed for the extra volts that a overclocked pc uses.
Yeah damn and blast! Just used a PSU calculator; http://www.antec.outervision.com/PSUEngine
It seems to need the minimim of 550w according to it. Ah well, I'll break the news to Mr. Skinflint later on! :D
Thanks Dude
