Cheers for that.
My cam covers only have one hose that needs connecting to the catch tank, suppose I could connect a length of pipe with a breather filter (on the end pointing towards the ground) onto the other barb.
Cheers for that.![]()
Do they still have to be plumbed into the intake system, to maintain the - pressure?
Why do you want one with a breathable cap? Or is it soley to catch oil than attempt to control crankcase pressure?
Handy in the sense that you don't need a breather filter for it. No doubt it would stink the cabin out though.
I'm not touching the crank case breathers, just a single 90 degree barb on one of my cam covers. I see people running a breather filter on it all the time, so surely fitting a catch tank and breather filter won't do any harm?
I just didn't want any crap going back through the throttle body and gunking up the sensors to be honest!
what sensors are inside your throttle body?
[TW]Fox;14977210 said:Noob time.
What are these for? Suprised to see them being fitted to 'normal' cars?
