I would just drain via the sump
Can you change the oil on my wifes Smart car for me please?
Heard about cheap ones of these snapping their ends off in the sump. beware!
Does your car hold 2 litres of oil![]()
water....:
You do need to get the oil hot, otherwise it will be nearly impossible to use. If you have an oil filter which is accessible from the engine bay (E.g. BMWs), then it is a no brainer.
