It threw up the oil level after a lengthy drive but the oil was genuinely low at that point.
Did they say why they need to strip it to diagnose the oil pressure issue?
sounds like completely unnecessary work
Stripping it could simply mean removing the sump to inspect the big end bearings, removing the pulleys, cambelt and front cover to inspect the oil pump...
A very wholly necessary process.
You can't just look inside it with a borescope and expect to be able to tell what went wrong and why.
OP, it's clearly FUBAR, why all the faf. Either pay to strip, inspect then repair all the faults or go and get hold of a second hand engine. It's that simple.
Cost of stripping + costs of parts + costs of repair = A number
Cost of S/H engine + cost of fitting = A number
Compare one against the other and go with the cheaper option.
and you're still driving it!!!!!!!!!
Sometimes that's the best kind of garage!
A friend of a friend has had his passat in and he didn't have a bad thing to say.
The noise goes away when I'm on the throttle and I think so.Just listened to that with headphones on. What happens to the noise when you blip the revs? Is it still on the original dmf?
Are you talking labour only? That's still £3k...at that level, I'd possibly call it quits and chuck the carI would go down the new engine route as you still do not have an explanation to why the oil pressure dropped, what damage has been caused to the engine/turbo. You should be able to get one fitted for around £1200-1500 going by a quick google search.
The rattle could be a lot of things DMF (pretty sure the DSG box still has one), cam chain tensioner, oil pump.. these are all common failures on the TFSI engine.
I'll give them a phone. Cheers mate.
Are you talking labour only? That's still £3k...at that level, I'd possibly call it quits and chuck the car![]()
