Physical condition aside, the two caveats with older amps are noisy volume potentiometers (sometimes source switching pots too) and capacitors drying out. Neither is a terminal problem, and noise on the pots is easy to check by switching and changing volume when there's no source playing. Capacitor issues are slightly harder to pin down unless there's a dead channel. Whiz the lid off and inspect visually. Look for signs of bulging tops or bursting at the bases. However, don't be tempted to recap unless there's a definite issue and you know what you're doing.
Just considering a refresh on my old 1998? Musical Fidelity A220 50W AB amp considering it actually gets used on the odd occasion compared to the CD player..
If they're like guitar amps then:
a) caps go and degrade - especially in the head class A and AB (the MF gets very hot!)
b) transistors also go - often those in the signal path
c) Keep in type - specifically as ceramics can add two orders of magnitude of harmonic noise in the wrong place compared to a poly for example.
I did find this place: https://www.hificollective.co.uk/catalog/components/capacitors.html which I may use to replace the Jamicon caps in the MF.
