- 30 Dec 2009
- NW London
Hi Guys,
This has got me stumped and I need your expertise please....
My old AMD Socket 939 PC died just before Xmas prompting the build of my new i7 beastie. However, I want to try and recover some of the data off my old PC before it gets stripped down and disposed of.
Just before it 'died' my old PC used to stutter and hang when loading XP Pro sometimes, but usually a re-boot sorted that. HOWEVER, just before Xmas I updated the graphics card drivers with the latest Nvidia set (was BFG 8600 OC) and from the next re-start, I've seemingly got no graphics card output whatsoever. I've tested the monitor and VGA / DVI cable and they are all fine, I've tried re-seating the 8600 card in both PCI-E slots and I've even tried re-installing an old 6600GT card - all with the same result.
As far as I can see the PC is starting (hard drive light / noise etc) but my monitor detects no signal and shuts down - I don't even get the BIOS POST screen. Now if it was a Windows / Driver issue I can understand it hanging at the OS boot stage but surely I'd still see the BIOS screen right?
Logic makes me think that it must be a motherboard issue (PCIE slot screwed, motherboard shagged in someway?) as I can't think of anything else that would give these symptoms but any ideas please or any suggestions as to how I can fix this?
Unfortunately I was young and stupid when I built this PC and I have the hard drives installed in striped Raid array so removing the hard drives to recover the data is not an option I think...
Hope someone can help!
Cheers,
Paul.
Cheers,
Paul.
