Plug it in to your current system and transfer the data, then format/install windows on the new system![]()
Sorry didnt quite follow. Plug my HDD with the documents on into another PC and transfer the relevant files across?
Yup, such as the PC your using now![]()
Plug it in (if its sata that is, if its IDE make sure you set the master/slave as appropriate first), turn your PC on and go in to the bios and make sure the boot order is correct and boot up![]()
Yeah it should but sods law says it wont. When I plugged in my new drives it had set the boot order to one of them rather than my RAID 1 array. It only takes a second to check.
