Not really no, I have been using one for nearly 2 years now most days and I have done the usual sensible things, like set the task bar to hidden, set dark mode wherever I can and windows will blank the monitor if I don't touch the mouse of keyboard for 5 minutes but beyond that I haven't changed what I do to try and avoid burn in as such, I have just used it normally and I don't see any real evidence of it yet.
If you do everything that you explictly advised not to do with it, and have bright white backgrounds with strongly contrasting static images on it, tool bars and such for long periods of time at high brightness, then yea you would no doubt notice some degradation in the time I have had it, as Hardware unboxed has demonstrated. It depends what you want the main use case of the monitor to be really.
My 2 year old OLED is an Alienware AW3423DW and my current main monitor on my gaming system is my new MSI 321URX which is 4k, 240hz gen 3 OLED and it's very, very nice indeed, also fits within your budget as I paid about 750 squids for it. You can get a 27" version of it for a bit less, although if I was going ot buy a 27" 4K monitor I would be inclined to go with the Asus ROG Strix XG27UCDMG ...mainly for the motion sensor over the MSI model.
