Hi all, my first post on ocuk so go easy on me.
Looking to build a pc to take to uni with me. Im doing aerospace engineering so i need a pretty good pc for CAD I also love my games.
Im trying to build a pc now (while i have the cash) that will last as long as possible.
Im gettting a 20" screen and wont be getting a bigger one so ive considered this with the choice of graphics card.
A high priority with this system is quietness as it will be left on in my dorm overnight and im a pretty light sleeper
To quietent the case ill cut out all the honeycomb fan guards, remove the psu finger guard and sandwhich a peace of dish cloth foam between the fans and the case and use soft push pins.
Here is what ive come up with so far, any suggestions and tips i would be really greatfull!:
http://img155.imageshack.us/my.php?image=pcjpgjk9.png
To quietent the case ill cut out all the honeycomb fan guards, remove the psu finger guard and sandwhich a peace of dish cloth foam between the fans and the case and use soft push pins. Here is what ive come up with so far, any suggestions and tips i would be really greatfull!:
