On startup I get the windows hardware disconnected sound.
I have narrowed it down to the top right USB port on the motherboard back plate,its the USB port where you can also reflash the bios . It's 100% that , because it only happens when something is plugged into there, and it doesn't matter what item. Logitech receiver, mouse, monitor USB hub.
I want to keep using it because right now I've already almost used up all the ports at the back,and it's the slower USB2 which is ideal for the mouse receiver.
However the good news is the port works fine ., works 100% even after the windows sound(and the sound only happens the once on startup), the items work properly in that port and I don't have to take them out or anything even after the windows sound.
It's just bugging me... have any of you experienced the same. I have the B450m mortar max motherboard.
