hi guys.
First post,be kind
I just picked up a little lenovo thinkcentre to use as a media centre for my living room.The pc is hooked up to and old 50" panasonic plasma with an active display port to hdmi connector and so far iam really happy with it,however iam struggling with slight oversan on the panasonic screen,ive set the res to match but still the edges are cut off.
I have reduced the overscan in the tv service menu as far as it will go but its still not enough.The graphics are an intelQ45/Q43 onboard chipset,and i cant find anything in the display settings that will let me reduce oversan,Do i need to buy cheap nvidea or amd card to get some extra software functionality,like the control centre or catalist to do the job or is there a 3rd party software that can help.
Any suggestions would be great. "Sorry mod,having trouble uploading specs picture"
thanks.
First post,be kind
thanks.
