- 27 May 2020
Hi all,
So I currently have my 10900k under water using an ekwb PE 360 Rad.. However I would like to add a 3080 to the loop (when able) would the one rad be enough or should I add another?
If I need another ill need to buy a new case, I'm also not sure what order to have the flow in if only one rad CPU or GPU first? obviously if I have two it Id have one between the CPU and GPU..
Thanks!
Thanks!
