Hello
I think I know the answer, but want to check.
I have a new mobo gigabyte ga-z77-3dh. I have a dual rad with 2 apache's. How do I set it up so they run in pwm mode. I have one attached to the cpu header, but the other is in a sys fan header. In the bios only the cpu one can be controlled by the cpu temp, the sys fans are based on system temp. How can I get both running off cpu temp?
I've looked at easytune and it looks a bit naff as again it won't let me set system fans based on cpu temp.
My case (arc midi 2) does have a fan controller so I could hook them up to that, but I like my big 140 fans to run off that rather than the mobo.
Any suggestions?
Thanks
Any suggestions?
Thanks
