UPDATE 13th March:
Before our update I would like to introduce our sponsor Alphacool! We have a very good friend working with/for Alphacool & am super happy to have them onboard. As far as sponsorships go we are usually doing work in return for people where we can so it is more of a trade. But welcome to the watercooling power!
First thing from Alphacool was this 240mm radiator. Real nice quality and lots of options with fittings. Very useful when working in smaller spaces. This is the 60mm version:
The copper logo or the radiator colour don't suit the build so we decided to make a cover. We also wanted to make a nice feature with their logo.
Started with the drawing part:
And onto the cutting. Recycling old acrylic in this build as much as possible, especially for the smaller parts. Cutting the female part:
After we used the 45° cutter to detail 3 of the edges, looking nice so far:
Moving onto the frosted red for the male parts. Same cutter, more recycling of old panels:
Here are the two pieces finished. The cutter was running a little thin on the last pass and left a few little bits needed cleaning up.
Using some lubricant and some careful teasing the male pieces fit into the female
*ok please go ahead and quote this, I really should have reworded this one*:
Just the inside of the O's to fit as a second inlay. Super happy with the results. Here are a few shots:
Moving back to the case we test if the new radiator:
Very tight fit here. Shaun likes to keep his tolerance very tight. If I say make it fit he will leave 0.2mm! Works really well here.
Next we decided to make a change to the front. We wanted to reuse the same technique that was used for the Parvum logo at the rear of the case and cut these new lines. We are both really happy with the results:
To finish today we today we test fit the radiator cover:
The bottom of this is actually a 45° cut going into the lower chamber 45°. This gives a really nice fit:
And a final shot of the case for tonight:
What do you all think about the new front? I'm sure a taste thing but we both really like it.
See you again tomorrow....!
