- 5 Jul 2003
- Cheshire
Evening all, I'm hoping one of you genius can help me out here, I've spent the last week trying to set up an openvpn server on a pi and I'm now stuck
Set up pi hole a couple of weeks ago and this works fine and blocks ads on my network.
Installed openvpn and easy-rsa using these guides
http://readwrite.com/2014/04/10/raspberry-pi-vpn-tutorial-server-secure-web-browsing/
https://sys.jonaharagon.com/2016/05/12/setting-up-an-openvpn-server-on-a-raspberry-pi-2-part-12/
had a few problems connecting to the server initially, bit of googling later and I can now connect to the server from a client so I'm happy the certificates are good, port forwarding is good and my ddns is setup in the router.
Now the problem, I can't connect to anything on my network except the pi running the server, I can see the pi hole page and I can connect via ssh but i cant see anything else.
Server.conf
sysctl.conf
firewall rules
openvpn.log
openvpn status.log
I've not changed any settings in pi hole since I installed openvpn, is this the problem?
Server.conf
Code:
local 192.168.0.113
dev tun
proto udp
port 1194
ca /etc/openvpn/easy-rsa/keys/ca.crt
cert /etc/openvpn/easy-rsa/keys/MYSERVER.crt
key /etc/openvpn/easy-rsa/keys/MYSERVER.key
dh /etc/openvpn/easy-rsa/keys/dh2048.pem
server 10.8.0.0 255.255.255.0
ifconfig 10.8.0.1 10.8.0.2
push "route 10.8.0.1 255.255.255.255"
push "route 10.8.0.0 255.255.255.0"
push "route 192.168.0.113 255.255.255.255"
push "dhcp-option DNS 192.168.0.1"
push "redirect-gateway def1"
client-to-client
duplicate-cn
keepalive 10 120
tls-auth /etc/openvpn/easy-rsa/keys/ta.key 0
cipher AES-128-CBC
comp-lzo
user nobody
group nogroup
persist-key
persist-tun
status /var/log/openvpn-status.log 20
log /var/log/openvpn.log
verb 1
sysctl.conf
Code:
net.ipv4.ip_forward=1
firewall rules
Code:
#!/bin/sh
iptables -t nat -A POSTROUTING -s 10.8.0.0/24 -o eth0 -j MASQUERADE
openvpn.log
Code:
Sun Mar 5 21:55:11 2017 OpenVPN 2.3.4 arm-unknown-linux-gnueabihf [SSL (OpenSSL)] [LZO] [EPOLL] [PKCS11] [MH] [IPv6] buil$
Sun Mar 5 21:55:11 2017 library versions: OpenSSL 1.0.1t 3 May 2016, LZO 2.08
Sun Mar 5 21:55:11 2017 NOTE: your local LAN uses the extremely common subnet address 192.168.0.x or 192.168.1.x. Be awa$
Sun Mar 5 21:55:11 2017 Control Channel Authentication: using '/etc/openvpn/easy-rsa/keys/ta.key' as a OpenVPN static key$
Sun Mar 5 21:55:11 2017 TUN/TAP device tun0 opened
Sun Mar 5 21:55:11 2017 do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0
Sun Mar 5 21:55:11 2017 /sbin/ip link set dev tun0 up mtu 1500
Sun Mar 5 21:55:11 2017 /sbin/ip addr add dev tun0 local 10.8.0.1 peer 10.8.0.2
Sun Mar 5 21:55:11 2017 GID set to nogroup
Sun Mar 5 21:55:11 2017 UID set to nobody
Sun Mar 5 21:55:11 2017 UDPv4 link local (bound): [AF_INET]192.168.0.113:1194
Sun Mar 5 21:55:11 2017 UDPv4 link remote: [undef]
Sun Mar 5 21:55:11 2017 Initialization Sequence Completed
Sun Mar 5 21:55:26 2017 82.132.242.86:42826 [user1] Peer Connection Initiated with [AF_INET]82.132.242.86:42826
Sun Mar 5 21:55:26 2017 user1/82.132.242.86:42826 MULTI_sva: pool returned IPv4=10.8.0.6, IPv6=(Not enabled)
Sun Mar 5 21:55:26 2017 user1/82.132.242.86:42826 send_push_reply(): safe_cap=940
openvpn status.log
Code:
OpenVPN CLIENT LIST
Updated,Sun Mar 5 22:42:32 2017
Common Name,Real Address,Bytes Received,Bytes Sent,Connected Since
ROUTING TABLE
Virtual Address,Common Name,Real Address,Last Ref
GLOBAL STATS
Max bcast/mcast queue length,0
END
