I've just updated opera to 10.10 (from 9.something) and am having trouble with the status bar. I like to be able to put my cursor over a link and have the link show in the status bar underneath the tab bar, but the problem is, even though the status bar is not set to 'off' in the options, and 'only show when needed' is not toggled (so it should show all the time) its not showing at all at any time.
Does anyone know how to fix this as its quite a major issue if such a simple feature can't be made to work right. It's also a pain when I selected to keep my preferences from my old opera install, and yet i lost my old theme (which i now cant find and the ones I can find suck) and it screwed up this status bar settings.
