So what ypu are saying in simple terms is if i have 2x140 fns as intake i should have 2x140 fans as out take, i was always under the assumption that i wanted more intake to force the air outYou will see a nice improvement in case airflow with MLs. I suggest you remove all PCIe back slot covers for move open vent area around GPU and thus more airflow from front to back and out of case. Removing all PCIe slot covers usually improves temps by several degrees as well as lowering noise levels. We need exhaust vent area to be at least as big as intake vent area, even more exhaust if not using simlar fans exhausting air out.![]()
Unless case is quite airtight outside fan holes, some air will always take short cuts.one problem with pushing more air in than being extracted is that the air going out will be from the easiest route possible so leaves dead air areas where as more air being extracted draws everything out.
Exhaust vent area is venting without fans. I almost never use exhaust fans in my builds anymore because I use good pressure rated intake fans that can easily flow air through the case. Just using intake fans is like only having a fan on front of a single tower cooler or only having fans on one side of radiator.So what ypu are saying in simple terms is if i have 2x140 fns as intake i should have 2x140 fans as out take, i was always under the assumption that i wanted more intake to force the air out
