Hey guys, hate to make another thread but it is techincally another topic so here it is.
I am building a Dual loop in the Thermal take Super tower 900 and have had some thoughts on what I should do in regards to my resevoirs /pump combo's. I could go the standard Cylindrical shape Pumps on either side of the bottom drive cages. Or I have been thinking of using these:
https://www.overclockers.co.uk/ek-w...rgb-pump-reservoir-combo-plexi-wc-9w4-ek.html
Here is the case to show where the Res/pumps would go:
https://www.overclockers.co.uk/thermaltake-the-tower-900-super-tower-showcase-ca-18f-tt.html
Now those rads supposedly come with mounting brackets, that I could adapt to mount vertically facing the front of the case/pumps facing mounting tray or it might work without much adaptation required. I'm going to have to make some modifications any way reading reviews on the casse seems to be easily made for Thermaltakes Res/pumps but not much else and I'm fine with that.
I also understand this type of case, or build is not for everyone. But I was hoping that someone with some experience either with the case, resevoirs and in general peoples opinion on whether it would look good or be a bit odd since those res plates would not be flush with anything sitting vertically, I may be able to fine away to have them flush against the glass, won't know until I get them I suppose.
Long story short, stick with conventional Res/pumps or go with something different?
Cheers for your thoughts
