Hi everyone.
The server is a HP ProLiant ML115 G5 and the specs are as follows:
Its going to be used for running Virtual Machines for me to have a play on. The RAM is being upgraded to 4GB of ECC RAM and seemed a bargain when I pressed the order button at a touch over £260.
I also have a spare 160GB Seagate HardDrive I plan on throwing in there to run the system in RAID1.
I was wondering if anyone had one of these servers and if so, how loud are they? What are they like for stability? Could this system last me say 2-3 years? Would it be possible to replace the powersupply to something more beefy or are they like the dells?
Its going to replace the current Dell which seems to go haywire when more 2 people VPN into it and the network card has a habit of randomly dropping the connection.
Finally no this is not for a business but my playbox![RedFace :o :o](/styles/default/xenforo/vbSmilies/Normal/redface.gif)
Type Server
Width 17.5 cm
Depth 42.6 cm
Height 36.7 cm
Weight 11.7 kg
Recommended Use Small business, corporate business
Product Form Factor Micro tower
Internal Bays Qty 4
Front Accessible Bays Qty 2
Server Scalability 1-way
Expansion / Connectivity
Expansion Slots Total (Free) 4 ( 3 ) x memory - DIMM 240-pin
1 ( 0 ) x processor
1 ( 1 ) x PCI-X / 100 MHz
1 ( 1 ) x PCI Express x16 - full-height
1 ( 1 ) x PCI Express x8 - full-height
1 ( 1 ) x PCI - full-height
Interfaces 1 x serial - RS-232 - 9 pin D-Sub (DB-9)
1 x keyboard - generic - 6 pin mini-DIN (PS/2 style)
1 x mouse - generic - 6 pin mini-DIN (PS/2 style)
6 x USB - 4 PIN USB Type A
2 x network - Ethernet 10Base-T/100Base-TX/1000Base-T - RJ-45
2 x display / video - VGA - 15 pin HD D-Sub (HD-15) ( 1 in front )
Expansion Bays Total (Free) 2 front accessible
4 ( 3 ) x internal - 3.5"
Manufacturer Warranty
Service & Support 3 years warranty
Service & Support Details Limited warranty - parts and labour - 3 years - response time: next business day
Processor
Type AMD Dual-Core Opteron 1214 / 2.2 GHz
Installed Qty 1
Max Supported Qty 1
64-bit Computing Yes
Multi-Core Technology Dual-Core
RAM
Technology DDR II SDRAM - ECC
Form Factor DIMM 240-pin
Features Unbuffered
Installed Size 512 MB / 8 GB (max)
Memory Specification Compliance PC2-6400
Memory Speed 800 MHz
Configuration Features 1 x 512 MB
Storage
Hard Drive 1 x 160 GB - standard - Serial ATA-150 - 7200 rpm
Networking
Features Wake on LAN (WoL)
Networking Network adapter - PCI Express x1 - integrated
Data Link Protocol Ethernet, Fast Ethernet, Gigabit Ethernet
Compliant Standards IEEE 802.3, IEEE 802.3u, IEEE 802.3ab
Remote Management Protocol IPMI 2.0
Ethernet Controller(s) HP NC105i
Miscellaneous
Features System password, power-on password
Compliant Standards ACPI 2.0
Power Jump to Top
Voltage Required AC 120/230 V ( 50/60 Hz )
Device Type Power supply
Installed Qty 1
Max Supported Qty 1
Power Provided 365 Watt
Environmental Parameters
Min Operating Temperature 10 °C
Max Operating Temperature 35 °C
Humidity Range Operating 10 - 90%
Storage Controller
Type 1 x Serial ATA - integrated
Channel Qty 4
RAID Level RAID 0, RAID 1, RAID 5, RAID 10
Cache Memory
Type L2 Cache
Installed Size 2 MB
Cache Per Processor 2 MB
Operating System / Software
Software Drivers & Utilities
OS Certified SuSE Linux Enterprise Server, Microsoft Windows Server 2003 Enterprise Edition, Microsoft Windows Server 2003 Web Edition, Microsoft Windows Server 2003 Standard Edition, Microsoft Windows Small Business Server 2003, Red Hat Enterprise Linux, Microsoft Windows Server 2003 Standard 64-bit Extended, Microsoft Windows Server 2003 Enterprise 64-bit Extended
Monitor
Monitor Type None.
Graphics Controller
Type Integrated
Installed Size 32 MB
Storage Controller (2nd)
Type 1 x IDE - integrated
