https://www.forbes.com/sites/johnar...ones-last-big-4k-blu-ray-player-picture-bugs/ ?The Xbox 1 X can't decode the colours right when playing a 4K HDR disc.
The Xbox 1 X can't decode the colours right when playing a 4K HDR disc. The UB900 tramples all over it.
And if you can't see the difference, then you have never used a UB900![]()
I haven't used one no. I did a check on youtube to see what was discussed on there. I saw a fella doing a comparison and it he did conclude the oppo player was much better but he also said it kinda required having them sitting side by side. For most people they would still be very impressed by the Xbox in isolation.
I get that dedicated players are better but it's diminishing returns.
Home Cinema always is.
They will always be better.
Panasonic does alright on the high end players. The problem with the OPPO was, it wasn't as good as the UB900 and has\had problems.
The issue is that the market for high end physical media players is tiny and Panasonic have other divisions keeping them afloat.
And I did just say I get that dedicated players are better. Not sure why you put what I said in bold??
I kind of agreed with you
I've tried Dolby Vision from Netflix and I'm not that impressed with it. Will be keeping the UB900 for a bit longer.
What tv are you using?
Nice try, but it's not the same. The xbox one messes up its read of the colour. It changes the data output. That's the whole point of much of this thread.This is the bitstream captured from an xbox one x console
1100101010111000011010101011100100101001100010101110001010101010
and this is from a dedicated 4k player
as you can see, the dedicated 4k player is far superior
It's much the same as with Blu-ray players. The more basic models provide little or no scope to tweak the picture settings. The better players provide far more control.I always thought the same as TheOracle stream of 1010 from the disk to the TV ie straight read and forward on to TV.
Would I be correct in thinking the difference is in the hw codec in the player adding effects (ie altering gamma curve in your example)?
Now as this is a 4k player thread how is hdr handled, by the player or decoded by the tv?
