Opteron 146 CPU VID
1 Mar 2006
Anyone know why this would happen?
Whatever i set the CPU VID to on my DFI Ultra-d, the voltage reported by BIOS and CPU-Z is 1.5-1.6V.
wanted to start low and work up to keep the heat down, so far clocking at 2.3GHz with a load temp of 38C.
any help would be much appreciated,
PS I am running 623-3 BIOS
THanks
if you set the voltage to 104% then thats why the readings are so high. 1.4v @ 104% = 1.456v.
thats assuming you have set the voltage to the correct setting in the first place.
i was expecting 1.456V, not 1.616V
and i have checked double checked and triple checked those 2 settings in the BIOS, is there one more i am overlooking?
I am in the genie section to set all this.
Craig
That's how I've got mine set up.
Jokester
thanks jokester,
at least i know i am doing that right.
ok, after some testing I find that my set value and my actual value are around 0.2V apart, so guees I have to keep testing to find if it is reading wrong, or setting it wrong.
hope there is nothing mroe serious than a ADC or DAC being stupid.
