Hello.Since i am a bit of a lazy newbe(yes NOOB
) on overclocking i want to
be proposed some setup for my pc.
I ve got an opteron 150(2.4ghz) the venus core(90nm).I was told that this is the E4 Revision.
I am on a shuttle sn25p with ocz platinum cas2 2gb ram.
I would like you to suggest me a setup that i will not face any major increase in heat cause i want to run my fans at ultra low if it is possible.
Thank you for your time
) on overclocking i want tobe proposed some setup for my pc.
