Gashman said:opterons use cherry picked cores don't they?![]()
Cob said:They use cores from nearer the center of the wafer. They require less voltage, thus giving better overclocking results.
weescott said:So you are saying that cores from the center of a wafer overclock faster? That Opty's only come from the center of a wafer?
Cob said:Cores near the center of the wafer will be of better quality than those nearer the outside. They are used for mobile chips (lower voltage is always needed for laptops) and chips that need to run at the top end of the chart (eg- the AMD FX range).
Opterons don't necessarily come from the center, but a 2.0Ghz Opteron will come from nearer the center than a 2.0Ghz A64. Hence why more 146 Opterons reached around 3.0Ghz than A64 3200+'s. The full 1mb of cache is also more likely to be available and working on cores taken from nearer the centre.
Jokester said:As far as I'm aware there's no variance in "quality" across a wafer, it's the quality of the wafers themselves that determine the performance of the chips and that's determined by all sorts of things, even the day of the week.
Jokester
Starfall said:The centre of the wafer recieves more uniform doping in fabrication, statistically centre dies will be superior to outer dies![]()
aztechnology said:My understanding ws that the dopant was introduced in the silicon melt, and whilst there are problems with non-uniformity, I don't think that these are particularly associated with the centre of the wafer. (Though its a long time since I studied all this properly)
Tetras said:All Opterons have 1MB cache per core (so 2MB total for a dual core chip) and are San Diego (Athlon 64) or Toledo (Athlon X2).
