Optical drive on side?
19 Aug 2009
Hi guys just got one of these:
and a normal optical drive tray, will i have any issues with the disks skipping, should have got a self loading drive!!!
Anyone use a normal drive tray sidewys?
Thanks
Jay
I have done in the past, works fine for normal size CD, doesnt work with those mini size CDs but how often do you use them?
Cheers guys :)
cmnder andi, same drive as i have too, just put my mind at rest! Just when you think you have covered all angles something springs to mind that throws doubts into it!
Thanks again
Jay :)
