Amp34 said:TBH I think some of you are going over the top with torch suggestions.
I would look at either Innova (link above) or LED-Lenser, both make excellent LED torches which are light, compact, can be carried anywhere and have good battery life without compromising on the output.
The X5 is a good torch for what you are looking for. I personally have a LED-Lenser V2 Aviator. It has 5 white LED's and a red one you can use seperatly. Its a superb torch, I have used it as a makeshift spotlight on my bike when cycling in the dark, thats how bright it is. It cost £35 so is pretty much on your budget too.![]()
Best bet is to go to somewher like Blacks or Cotswold outdoor and have a look at torches there, stay clear of Millets as they don't really have anything of quality in them.![]()
Amp34 said:Not too bad a torch although I would hate to see the battery life of that though. 5 minutes anyone?![]()
http://night-ops.com/Gladius-6V-LED.htmlnight ops said:Runtime
90 minutes of maximum light output at the Full Power Setting.
400+ hours @ lowest setting. (approx. 0.8 lumens)
Locrian said:Some of you are really, really scary people
I just wanted you to know that![]()
the 90 minutes estimate is for when it's on full power. A 'civvy' would rarely need it that bright, so it would last considerably longer.Amp34 said:![]()
Especially as I look like i have liver disease.![]()
90 minutes isnt too bad if your in SF or the army and change batteries every time but for an average civvy it would be a killer.
rlm said:I do a lot of walking in the dark, usually through some very unlit areas, at present I only have a tiny LED keyring torch that isn't much use really. I'm looking for something with a decent battery life (multiple LED maybe?) and would also like it to be a easily carryable weight so I can take it whenever I want. It needs to be fairly bright becuase as I mentioned some of the areas I walk have no light at all.
I wouldnt even know where to start, so I'm just wondering if others here already have something that might fit the bill, or know of any suggestions as to what I should get. Budget is upto around £30.
Thanks.
Spacky said:Petzl torches (imo one of the best makes)...forget a hand torch. I do night walking its awesome but a trip or slight fall and you got one hand to stabilise your fall, hence why I bought one. Provided good vision in rain and fog as well. I did a lot of research into this as am an outdoor gear fanatic. So this for my budget (and yours) I suggest the one I have specced you here(maybe worth looking for a better price on the net though).
I got one of these Petzl Tikka XP
