optical output vs spdif which is better ?
Suspended
8 Jul 2006
Just noticed my 680i motherboard only have optical out, As I am in to my home cinema and all ways want the best Quality I am unsure if optical out can produce good Quality.
which is better and optical out or spdif ?
16 May 2005
Cold waters
SPDIF is the protocol, so optical can carry it too. If you mean optical cable vs co-axial cable for digital audio then both have their advantages. Supposedly co-axial is perhaps slightly better in theory, but you will never notice a difference. Not worth worrying about :)
17 Aug 2003
Woburn Sand Dunes
if your in to your home cinema you should already know the answer!
11 Dec 2003
Shipley
Like wush said, they are both SPDIF ;)
As for the cable,
Optical advantages:
Immune to electrical interference, really unlikely to be a problem in your typical house unless you intend to run it under your washing machine or something :p
Optical disadvantages:
Usually more expensive.
Quite easy to knacker the cable if you kink it.
Co-ax advantages:
Cheap as chips, common as muck 75 ohm cable.
Rugged.
Co-ax disadvantages:
Not totally immune to electrical interference, but you really would have to be trying for it to be a problem.
Quality is the same for both as they carry identical bitstreams.
Top
