I am wondering if there is a device that can take in like 3 or more optical inputs and mix (the sound) them together into one optical output?
And before you say, a switcher is not the answer.
Edit: Sorry, i think i am wanting a "AV Receiver" ?
I am confused.
Edit2: after much searching i found this: http://www.sony.co.uk/product/hcs-home-cinema-receiver/str-da3500es
It has 4xhdmi in, 1 hdmi out, plenty of optical in/out. what do you guys think of it? The optical out will plug into logitech 5.1 surround. Computer, ps3 and any future devices can plug into the hdmi in on the reciever, then hdmi out to the hdtv.
It is expensive but if theres something that does what i want for cheaper then thats great
Some cheaper recievers seem to lack optical out for some reason.
I am confused.
