Hi, I purchased an Optical Splitter, and 3 x Optical leads.
I was looking to connect 2 consoles to one optical input on my amp, so I’m basically trying to use the splitter in reverse. I have searched these and other forums to find that it does work as long as it’s not with something like a sky box, which still outputs an optical signal even when off.
I have connected them together, but I get no sound from either consoles.
I have checked:
That only one console is on at a time.
That any of the consoles output an optical sound when off.
All cables are working perfectly without the splitter.
That there’s a signal (red light) outputting from the optical in cable.
I’m just confused on what it could be? Oh, and I have tried using the splitter the correct way, and still doesn't seem to work.
Is there something I may have to change on the amp?
Cheers
Adam
I have checked:
Cheers
Adam
