Optical Vs Spdif Coaxial??
28 Jan 2007
Manchester
Which is better, some motherboards have both of these outputs, my receiver has both inputs, just wondering which gives the best sound quality and are there any other advantages of 1 over the other?
both the same. optical has an advantage over long distances (10m +) and coax has the advantage of the data having to go thru less conversions (electrical > optical > electrical in the case of optical leads) but unless your the type to spend a few grand on a cd player, you wont notice any difference there might be:)
cool, my p965 ds4 had coaxial spdif, my new ip35-pro has optical only so i've had to buy a 2metre optical cable, was just wondering which was the best.
thanks.
