Good way to start might be to read basic guide to how airflow works and how to optimize case airflow in link below:
https://forums.overclockers.co.uk/t...-i-put-my-temp-sensor.18564223/#post-26159770
Link below about how airflow and static pressure specifications relate to real world use might aldso be of helpful:
https://www.overclock.net/forum/22644574-post11.html
Pure Wings 2 120mm fans are really not up to the task of case intake fans. Even at 1500rpm they only make 1.25mm H2O static pressure or 51.4cfm. By comparison, Silent Wing 3 120mm at 1450rpm make 1.79mm H2O static pressure or 50.5cfm airflow. Fan airflow specification is how much air fan can flow at full speed with no resistance .. a fan on a stand with nothng around out. Static pressure is how much pressure fan can push into a sealed container at full speed. Neither of these applications is a way we use our fan.
Static pressure rating is key to fan's ablity to flow a decent amount of air by being able to overcome resistance of things like grills, filters, cables, etc and be able to flow a
High static pressure rating is key to having good case fans. Case intake fans need to have 1.5mm H2O static pressure rating or greater at 1300-1500rpm so they have high enoujgh pressure rating at speeds we normally run our case fans to overcome grill and filter resistance.
3x 120mm high pressure rated intake fans with all openings not covered by fans in fan mounting panel blocked so air can't leak into front of fans and go in circles but must flow on through case and out the back. Remove all PCIe back slot covers to increase rear vent area so more air can flow past GPU and out the back. With this setup of high pressure rated intake fans no exhaust fans are required. End result is a cool and quiet running system.
I would suggest PH-F120MP fan 2-pack for £14.99 so £7.50 a fan, but they are our of stock.
While their pressure rating is not super high at full speed, they make more pressure between 600-1200rpm than others so move more air through grill and filter applications in speed range we use our fans.
