- 15 Feb 2010
I would like to set my RAM to the fastest voltage/timing BUT i want 95%+ reliability. I have OCZ 1066 Reaper With Heat Sink, DDR2, 4X2GB RAM in dual channel interlaced mode. I set the timings in the bios to 5-5-5-18 and left the voltages as default. With an Asus P5Q Pro Turbo MB and a Intel Quad Core Q6600, 2.4GHZ CPU
According to speccy and CPUZ it says max bandwidth "PC2-6400 (400MHZ) is that right? And CPUZ in the voltages line says 1.80 on the first three then 2.100 on the last one
Are my setting optimal? If not what should i change what to? Perhaps an easier way is to use on-the-fly overclocking for the CPU/RAM when using certain program does the Asus software do this; what would people recommend? Thanks
