Hi all,
I regularly work on 300 to 500MB Tiff files and think disk performance is holding my system back - the main problem I get is disk trashing when PS is writing/reading undo data. I have a large fixed size swap file and a large PS scratch space defined.
System is a Q6600 (stock speed atm), P5Q deluxe, 4GB of fast memory, winXP and three 750GB sata II drives in Raid 5. At the moment XP is on the first of the four partitions in the raid array, apps and swap are in the same partition and PS scratch space is on another partition.
So down to my main question...
I've just bought a 150GB 10,000 rpm Raptor drive and win 7 ultimate 64 bit. I'm planning to use the Raptor for the OS and apps and keep the Raid 5 array for my data. Bearing in mind that I mainly want to see a performance increase in PS what's the best way to set this up? Where are the best places for the windows swap file and PS scratch space?
All info greatly appreciated
Cheers,
Ian
PS - it would be good if I could dual boot my existing OS and win7 for a while... there's always the odd thing that I manage to forget to backup, export or write down when I do a clean install. Not data as that's always separate, just little things like Filezilla accounts, music playlists etc. Any tips on dual booting with my new setup?
Cheers,
Ian
