Opty + Overclocking
  • Thread starter Thread starter amx
  • Start date Start date
amx
amx
2 Dec 2005
If you're going to be overclocking, is the Opty 170 worth the extra over the Opty 165?
The only difference I know of is that the 170 has a 10x multiplyer where the 165 has a 9x?
it's only worth it if you know your gonna be held back by the fsb of the motherboard, inm which case that extra multi will come in handy. otherwise they are identical:)
My brother is upgrading his machine, and i'm gonna go for the MSI Neo4 Platinum, but nobody seems to have any info on it.
The DFi puts him over budget, and i've been reading bad things about the asus A8-MVP crossfire board at the moment.
Are there any other options to consider? Ideally i'd like to get to 285Mhz FSB (2.55Ghz), but depends on the luck of the draw with the chip :/
Difference between the 165 and 170 is not just the multi. The stock speed of the 165 is 1.8 and the 170 is 2.0. I take it you want a crossfire board because you have ATI x-fire setup?
well obviously the speed is different but he knows that.
The only difference is the multi. Thats what makes the speed different :o :rolleyes:
Hehe, i gathered the clock speed was different as 9x200 and 10x200 is 1.8Ghz and 2.0Ghz respectively :P
I plan to overclock it for him (or try :P), so I want to get as much out of the CPU as possible.
It will only be a single card setup (an ATi X1800XT), and the budget is the deciding factor, so the motherboard has to be around £70ish, hence the MSI Neo4 Platinum or the Asus A8-MVP. Unfortunately, he can't stretch to the DFI ultra.
I'd consider an Epox nForce 4 board. Second only to DFI in terms of overclocking and can sustain 300+ HTT speeds
The MSI though is still a good board
Where do i find the Epox boards on the site, as they no longer have a section under 'motherboards'
Unfortunately they've stopped selling them so you'll have to get them else where
Look for the 9NPA or 9NPA+ (IIRC - the latter has the nForce 4 Ultra chipset which offers SATA II and firewire over the standard nForce 4). The nForce 4 Ultra has a few other improvements but those are the main two
if you are planning on overclocking then don't go for the msi k8n neo4 platinum. I have just posted a thread in the oc & cooling section. I could only get mediorce overclocks with it. swapped to an asus a8n sli premium, and its MUCH better
My brother managed to con me out of the £20 extra for the DFI board, so i'm hoping I can get his Opty 165 to 290x9 with some a 2Gb G-Skill ZX kit and a thermaltake big typhoon.
He's also conned some money out of my mum to get a Lian Li PC7+ and a Enermax 400 Watt modular PSU.
If i don't get good clocks though, I will cry.
A lot of people have said that the 3800 X2 clocks well, so I may save some cash and get that instead although I realise he'll lose 1mb of cache (512kb per core)
Like ajgoodfellow said the Epox 9NPA boards are great, I have one myself. The 9NPA+ Ultra can be picked up from a competitor for £66 inc. VAT if you look hard enough :)
It does, but not as well as the Opterons. They tend to clock a little higher and they have double the cache
I'm just gonna butt in here and check something:
Opty 165 + DFi Ultra-D + G.Skill 2GB DDR HZ PC4000 should hang together nicely?
Sounds good to me.
Opty 165 is the badger :) (Well, unless you can afford the 170...)
GSkill RAM doesn't seem to like tight memory timings though, so make sure you can clock it until it purrs.
