Type: Small FFTs - stress CPU Min: 8 Max: 64 InPlace: Yes Mem: 8 Time: 15
CPU: 2531MHz FSB: 220MHz [220MHz x 11.5 est.]
18/12/2007 18:04 Beginning a continuous self-test to check your computer.
Press Stop to end this test.
Test 1, 800000 Lucas-Lehmer iterations of M172031 using 8K FFT length.
Test 2, 800000 Lucas-Lehmer iterations of M163839 using 8K FFT length.
FATAL ERROR: Resulting sum was 122279472104932.4, expected: 122279471842793.2
Hardware failure detected, consult stress.txt file.
Torture Test ran 4 minutes 21 seconds - 1 errors, 0 warnings.
Execution halted.
AMD 64 4000+ 220 X 11.5 @ 2532 AT 61C MAX! 1.550 volts, (1,5 standard) (max 1.7)
pc 3200 ram @ 194.8mhz fsb:dram cpu/13 - dunno what that means
Fans on FULL, should i get a processor heatsink and fan so i can overclock more as 2.5 is poor with orthos errors correct?
What does it mean coz 61 is hot isnt it
Execution halted.
