NEW EDIT ***
My system runs stable on 210 FSB but i cant even get 215 fsb which is an 8% overclock! i have upped the voltage on my cpu from 1,500 to 1,650 and the next higher step that my mobo enables me is 1750 WHICH IS THE MAX setting so i am scared to go any higher,
Here is a screenshot i got with the error and my current setup,
Setup:
AMD 4000+
2GIG PC 3200 Corsair 3-3-3-8-11
GIGABYTE GA K8NXP-SLI
X850 XT PE (480/621)
POWER SUPPLY IMPORTANT CHECK PLEASE, (Thermaltake butterfly 480w)
I read a few posts ago about my 12v being crap and in the everested screenshot is that high for my PSU? is it dangerous?
Test 1, 4000 Lucas-Lehmer iterations of M19922945 using 1024K FFT length.
FATAL ERROR: Rounding was 0.4985428004, expected less than 0.4
Hardware failure detected, consult stress.txt file.
Torture Test ran 0 minutes 4 seconds - 1 errors, 0 warnings.
Execution halted.
AMD 64 4000+
2583mhz
12multiplier
215 FSB
862HT LINK
Memory 161mhz
I did not get error when running 210FSB?
Also i cant set the memory 1xxmhz its done by 2/1 2/2 2/1.5 etc
Temps are low 40's, Voltage is 1,500 can i up it to 1,550? is it safe etc? HELP ME OC PLEASE!
Setup:
AMD 4000+
Execution halted.
AMD 64 4000+
2583mhz
12multiplier
215 FSB
862HT LINK
Memory 161mhz
