Ive just done this from a 90gb ssd to a 64gb ssd. I made a image of the 90gb ssd using acronis true image, then I just restored the image to the 64gb ssd.
Remember if the ssd that your restoring the image to isn't new, secure erase the ssd first.
samsung 830 is new yes.....i would like to avoid acronis true image, because it interferce with XTREAMER WIFI not showing shared maps to watch movies on my TV etc.
Intel has a very good app exclusive for cloning hard drives
You have to have one present in your system to use it
I did a lot of cloning on mechanical drives using the software
But you can not clone a partition, only an entire HDD
So if you migrate from a 1TB HDD to a SSD you have to delete D otherwise it will not let you not enough space on the ssd for cloning
