Hey all, i've got quite an annoying and worrying problem on my hands here, basically i had windows 7 installed, but got a virus, so reinstalled it, this was installed on my HDD, and also a spare copy on my SSD which i know you should disable defragmentation for, but i forgot to.
Once it was installed on the SSD, i deleted it from the HDD, so that copy became unusable, but i forgot about the defrag prevention.
Anyway, i flashed the bios to the latest version ( using the executable Liveupdate platform from MSI thinking its safe ) and it restarted the pc, then when i tried to load the OS, bluescreen, tried again, bluescreen, at the same point of windows startup, i don't know what i did but the next part is what really confuses me
When i attempt to install vista now (yes vista, as i've lost the windows 7 disk!
), using the disk, it decides that it dislikes the hard drives ive got in the computer, i don't know why but it asks for Drivers?!
so does anyone know whats up here, is it because ive flashed the bios, if that fails does it cause harm to a system ( it says its the version i flashed to when i check it in the Bios) and if not, how would i install vista again, id like to get the pc back working again soon, ive just completed mw3 on veteran and wanted to upload it all to youtube!
i will get a new copy of windows 7 soon as it is superior to vista, but as long as the pc gets back up ill be happy!
If it helps my hard drives are 2 Samsung Spinpoint F4's and an OCZ Vertex II
Cheers for any help in advance!
Dantoshou
), using the disk, it decides that it dislikes the hard drives ive got in the computer, i don't know why but it asks for Drivers?!so does anyone know whats up here, is it because ive flashed the bios, if that fails does it cause harm to a system ( it says its the version i flashed to when i check it in the Bios) and if not, how would i install vista again, id like to get the pc back working again soon, ive just completed mw3 on veteran and wanted to upload it all to youtube!
Dantoshou
