Try either command shift 3 or command shift 4, will turn your screen grab into a png file
where do i paste it too or view it ?
It will automatically create a file for you. On the desktop by default I think
The Mac OS X Software Sticky said:Cmd-Shift-3
Take snapshot of the whole screen
Cmd-Shift-4
Take snapshot of the selected area
Cmd-Shift-4-Spacebar
Take picture of a window
Escape
Cancel
Hold Spacebar after Drawing the region
Move the selected area
Hold Option
Resize selected area
Hold Shift
Resize selected area horizontally or vertically
It's a copyright thing with DVD Player. Use VLC, it'll allow you to take screen grabs with it.
